96 Accord Transmission question...
Old Feb 7, 2005 | 04:11 PM
OldMan's Avatar
Donut Killer
Originally Posted by psycho
I have a 94 accord and have the exact same problem. I've had the car for more than 2 years now, it just got a little worse than it was. From what i heard, most of the time it is the Vehicle Speed Sensor "VSS", which sends the speed reading to the TCU so it shifts in the right time. I've always wanted to change the VSS and see what happens, but never had the chance to. If you ever change it and it makes a difference, let me know so that i change mine too
Since the car was under a warranty, I paid the $$ to have it done at Aamco. I didn't want to void the warranty by doing the work myself. Any ways, it did nothing. We got the car less than 2 miles away before the 'Check Engine light' came back on. I scanned it and it was the "Input Speed Shaft Sensor Malifuntion." The exact code from before! I took the car back and they told me it is the TCU. I am done with them and these problems. I am just going to find one at the auction and hope that the replacement parts don't have the same problem!
SC Motorsports
11801 State Road 52
Hudson, FL 34669-3092
(727) 856-8768
FordSpeed Racing
11733 66th St., Unit 123
Largo, FL 33773
(727) 549-8255
Dynojet Chassis Dyno
Old Feb 7, 2005 | 04:18 PM
crazyhatch's Avatar
someone's been in here b4
i have had several accords with that code and it was all the same problem they were over filled by an aftermaket shop cause they did not know to check the fluid when the car was shut off not when it is running like american cars if you drain the tranny fron the drain plug on the botton when you fill it up it should only take 2 1/2 -2 3/4 quarts of fluid and clear the code
Old Feb 10, 2005 | 02:30 AM
OldMan's Avatar
Donut Killer
Easy enough, I will give it a shot as soon as I can.
Thanks
SC Motorsports
11801 State Road 52
(727) 856-8768
FordSpeed Racing
Largo, FL 33773
(727) 549-8255
Old Feb 10, 2005 | 09:34 AM
accord95's Avatar
USMC
i will check on my car to see if it still has the TCU(i had mine converted to standard). if it does, i'd more than happy to let you have it.
TR happily married crew-member #2
___________________
Originally Posted by Troux
This is the internet. You're just supposed to talk up whatever you do know as if you're a salesman for it. i.e. I drive a Supra and a Corolla therefore 2JZ is the greatest and so is the 4A and I don't care about anything else because it's all crap since I don't have it. I also have a stack of $20 bills in front of me, therefore 20>50 and 20>100 and 20>1000. $20 bill FTW.
Old Feb 10, 2005 | 01:00 PM
crazyhatch's Avatar
94-97 rearly have tcm problems just crappy trannys
Old Feb 11, 2005 | 07:37 PM
OldMan's Avatar
Donut Killer
That would be great, as I can rule out the TCU.
(However, I will be honest when I say I don't think it will change anything.)
Thanks again....
SC Motorsports
11801 State Road 52
(727) 856-8768
FordSpeed Racing
Largo, FL 33773
(727) 549-8255
