Turbo exhaust sizes
Turbo exhaust sizes
hey guys, i just got exhaust bent for me today, but my buddy who bent it, had broken the 2.5 pipe die a day before hand and hadn't gotten a chance to get a new one yet. so I ended up with 2.25 crush bent pipe. now i'm sure this is fine for my b16a3 but for my turbo I am not sure if it will be.
my goal is 250whp will this be big enough pipe for it?
Alarm Crazy!
|| 1994 Honda del Sol vtec || B16a2 || 2 engines in garage one in car w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Alarm Crazy!
-John
Aim: le lead
Cell: (813)843-8523
i think alot of people run 2 1/2 to 3 inch on turbo cars but it all depends on ur setup all cars are different
DONT SLEEP's penis tastes soooooo good
drag manifold to a precision sc50 .48 hot .60 cold snail...i believe the opening on the turbo is 2.25.... so since out of the turbo it is only 2.25 i can't imagine needing bigger on the exhaust
Alarm Crazy!
-John
Aim: le lead
Cell: (813)843-8523
Alarm Crazy!
-John
Aim: le lead
Cell: (813)843-8523
Originally posted by 91Crx but i heard vtec
i think alot of people run 2 1/2 to 3 inch on turbo cars "but it all depends on ur setup all cars are different"
thats why i put it depends on ur setup
anyone who knows what they are talking about want to comment?
Alarm Crazy!
-John
Aim: le lead
Cell: (813)843-8523
Alarm Crazy!
-John
Aim: le lead
Cell: (813)843-8523
Personally, I would run atleast 2.5 inch exhaust.
I run a 2.5 inch d/p to a 3 inch thermal exhaust.
Try out the 2.25 and see what numbers you make on it, then go from there.
2.25" CRUSHED?!?!?! NO.
Just imagine, anywhere a 2.25" pipe is crush bent, it makes it 2" or smaller... That will make your turbo seem laggy as hell, and you will probably make a lot less power than you should..... I would at least do 2.5" mandrel bent, but I would prefer 3"...
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Sucks. Go atleast 2.5" like the other stunnas said.
Guest
Posts: n/a
Although I ran a crush bent 2.25" on my old setup, because I was lazy. My downpipe was 2.5" mandrel, so that made up for it when I wanted to go out and play.
Anything less then 2.5" is going to be very restrictive. Once you start making ~250whp, it might be time to upgrade to a 3".
i would get as large as you can and as mandrel as you can, with a .48 you honestly on a B16 not see much lag at all, but i would recommend getting at least a 2.5 inch if you could 3 inch but i know it is a little more costly
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
