need help with b16 bearings
i went to honda to get bearings for a stock b16a crank and b16a rods, im not to sure of what kind i need, so i went there and asked them for a b16a si motor 1.6 , rod and main crank bearings and they told me i need to know the color ?? can someone point me in the right direction or what i need exactly ,thanks for any help, and yes im looking for a helms
If you don't know what they are talking about you should consider getting someone to assemble your motor for you.
Gracie Barra Clearwater
Get a helms manual and someone who has spec'd out bearings before help you with the ordering.
MAIN:
Letters are on the block, numbers are on the crank, put the two together to get color code
ROD:
Letters are on the crank, numbers are on the rods, same process as above
Blue .0594-.0593
Black .0593-.0592
Brown .0592-.0591
Green .0591-.0590
Yellow .0590-.0589
Pink .0589-.0587
Red .0587-.0586
BC = IDBT β ODC β (2 x BT)
BC = bearing clearance
IDBT = inside diameter of bearing tunnel (housing bore)
ODC = outside diameter of crank journal
BT = bearing thickness
Main Bearing thickness by color
Blue 2.013-2.010 mm 0.0793β- 0.0791β
Black 2.010-2.007 mm 0.0791β- 0.0790β
Brown 2.007-2.004 mm 0.0790β- 0.0789β
Green 2.004-2.001 mm 0.0789β- 0.0788β
Yellow 2.001-1.998 mm 0.0788β- 0.0787β
Pink 1.998-1.995 mm 0.0787β- 0.0785β
Red 1.995-1.992 mm 0.0785β- 0.0783β
Rod bearing thickness by color
Blue 1.510-1.507 mm 0.0594β- 0.0593β
Black 1.507-1.504 mm 0.0593β- 0.0592β
Brown 1.504-1.501 mm 0.0592β- 0.0591β
Green 1.501-1.498 mm 0.0591β- 0.0590β
Yellow 1.498-1.495 mm 0.0590β- 0.0589β
Pink 1.495-1.492 mm 0.0589β- 0.0587β
Red 1.492-1.489 mm 0.0587β- 0.0586β
Although most people do not have inside micrometers, bearing micrometers or snap gauges,
you can still use this chart when using plastigage to check bearing clearance.
If you want to increase or decrease a bearing clearance, you can calculate how much
of a color change is necessary by looking at the changes on the chart. Remember you can
mix colors for even a more fine-tuning but it would not be wise to jump more than one color.
In other words, do not mix a brown and yellow bearing together to equal a green clearance
value. Just use the greens together. It is ok to mix a green with a yellow or a green with a
brown. When doing your rebuild and replacing bearings with like colors, you still must check
your results with plastigage to be sure. Donβt assume anything. Also remember, when swapping
to aftermarket rods, throw the color codes away as they will not work anymore. You need to
start from scratch to obtain your desired clearance. On the other hand, you really cannot
measure accurately to the nearest .0001β without machinist quality tools, so donβt get carried away
on that last one ten thousandth of an inch variance.
ROD:
Blue .0594-.0593
Black .0593-.0592
Brown .0592-.0591
Green .0591-.0590
Yellow .0590-.0589
Pink .0589-.0587
Red .0587-.0586
tonight which one do i get
