Balancing . .
I just got back from engine lab. And talked to him about the ctr crank pulley. I told him the story on how they are known to shattering oil pumps because there is no harmonic balacner. He said basically " Thats a balacning problem" So iam thinking if iam balacning the whole bottom end with the crank pulley to the machine it would be fine to use.
I already told him that its going to see at the highest 10K although I don't really see any reason to go that high. But just in case, leaves room for error I guess. Iam doing the street performance balance which I think and he said would be best. What do you guys think about this? If not its easy to switch over to a b16 crank pulley.
I recently saw a special on motor balancing and the filmed
it at Engine Lab so I was going to ask the same question.
If you've go the money and you want your motor to last, it
seems worth the $$$ to have your bottom end balanced.
On the show I think the said a 6oz imbalance at 8,000 RPM
is equal to 150 lbs or imbalance!!!
And over time that will destroy your motor.
Not sure who else here in Florida does motor balancing, but
I am looking into it as well.
Florida CRX Meet 2011 http://www.facebook.com/pages/Florid...2354313?ref=ts
what does that have to do with what my question is? I just want to know what others think about the ctr pulley being balacned with the bottom end together be find to use on a high rpm motor. Since there are such horror stories of this picticular pulley destroying oil pumps and ruining motors.
Guest
Posts: n/a
The theory there is sound, and this should work if the entire motor is balanced with the crank pulley. However I must say it seems rather an expensive solution to your problem... why not use a pulley that is made for your motor, and already balanced? I may have missed something.
Well at the time I found this out about the crank pulley I had already had the bottom end at engine lab and had already bought the ctr crank pulley. So iam thinking well since the motor is getting balacned might as well have it balacned with the crank pulley I want to use. And since the problem with ctr's c.p. is a balacne problem cause its just the c.p itself.
I thought maybe this would cure it, since it is a balanceing issue. I had already paid and plained to get the bottom end balacned using this crank pulley or not.
does anyone have a thread on bottem end blueprinting and balancing. I'm heading over to H-T to do a quick search now, but if anyone has anything specific I would really appeciate it. I have no fucking idea what any of this means....other then you will break shit if its not done right
Racing Integration
LHT Performance
My tuner is named Alpha
Racing Integration
LHT Performance
I find that rather interesting, does anyone have any links as to how this process is preformed? and also how much is the average cost of this sort of thing?
Alarm Crazy!
|| 1994 Honda del Sol vtec || B16a2 || 2 engines in garage one in car
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Alarm Crazy!
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Racing Integration
LHT Performance
Racing Integration
LHT Performance
