high ass idle
Old Jan 11, 2005 | 06:26 PM
McdeezNutz's Avatar
HI KIDS!
Default high ass idle
when starting my car up when its cold it immeadiately idles at 3k and once warmed up it stays at 2k , i just put some dc sport headers on about 4 weeks before that, could effect it? any way i need input......i'm afraid my shit is goin to break. please help
-steven
Old Jan 12, 2005 | 06:30 AM
Jaso0on's Avatar
Is now ballin!
It's more than likely ur tps (throttle position sensor), does the car ever have a loping idle (up and down, up and down)
RIP Kevin (Slo_Si) Gonzalez - 09/13/2006
Old Jan 12, 2005 | 06:30 PM
hybrid ek's Avatar
Has a little 1 on the way
Check for vaccuum leaks
Originally Posted by MajinVegeta
body kit-$400 dollars.
'custom' interior with walmart floor mats- $200
turbo gauges without boost- $200
realizing all that money wasted on rice- priceless.
Old Jan 12, 2005 | 06:48 PM
McdeezNutz's Avatar
HI KIDS!
my car doesn't lope, i also have the idle screw on top of the throttle body all the way in , what kind of vaccume leaks should i look for?
Old Jan 13, 2005 | 05:56 AM
DA92driver's Avatar
check the vacuum to the MAP sensor.i had some what the same problem.and the idle was rough..it fixed it. runs great.-Greg
Old Jan 13, 2005 | 11:33 AM
webdog's Avatar
Theres also a sensor thats connected to the bottom of the throttle body that screws in. Mine used to unscrew itself and cause my idle to stay up in the 3 grand range. I screwed it back in with some loctite and havent had any problems since. This is on an integra.
Old Jan 14, 2005 | 08:21 AM
1QWKCRX's Avatar
That CRX Guy
Depending on the motor, the Electronic Air Idle Control Valve
is usually located on the back side of the tb and they do go bad
over time on our cars. You may want to try pulling one off of another car and see if it helps.
Florida CRX Meet 2011 http://www.facebook.com/pages/Florid...2354313?ref=ts
