ITR Girdle on lsvtec..
Old Jan 9, 2005 | 06:49 AM
TSX24L's Avatar
Default ITR Girdle on lsvtec..
Will the ITR Girdle fit on all 5 mains or do I need to get the special GE Main Girdle set? Comes with oil screen etc..
Whats the differance between using the ls oil pickup and the gsr one or itr's?
Motor is a B18B1 96 Integra LS.
Old Jan 9, 2005 | 11:14 AM
2ndGenT3g's Avatar
look at this setup its big body smiths setup nice lsvtec ,clean also
http://www.cardomain.com/id/bigbodysmith
he uses all itr
||=|| ((O)) ||\\ || |D) //-\\
DB2-SOLD!
Dc5 Type-S-SOLD!
97 civic 4dr-SOLD!
05 civic 4dr EX SE-SOLD!
08 Acura TSX_ 6mt
Old Jan 9, 2005 | 11:29 AM
TSX24L's Avatar
yea he has a very nice car. Can't believe he is selling it.
Old Jan 9, 2005 | 02:26 PM
mtber's Avatar
Default Re: ITR Girdle on lsvtec..
A ITR/GSR girdle will NOT fit without machine work.
You also have to take into consideration that you would need a p72 oil pickup & oil pan if you go with a block girdle.
Honestly, you don't need one unless you plan on revving past 9k everyday.
Old Jan 9, 2005 | 02:53 PM
rangcrx's Avatar
engine building &best
if your getting i for free i would get it shaved to work if your paying for it save the extra money and use this one i use it on my b16 its a strong beautiful part i am very happy with it http://azracemachine.com/CrankGirdle.htm
i love AUTOZONE
Old Jan 9, 2005 | 04:27 PM
TSX24L's Avatar
rangcrx: Will that fit on a stock oil pan? What oil pickup did you use? Will this fit for my setup?
Old Jan 9, 2005 | 04:34 PM
mtber's Avatar
Again, to use a girdle you need an oil pan for a motor that has a girdle from the factory such as a gsr/itr, hence you need a p72 oil pan & oil pickup.
Old Jan 9, 2005 | 09:59 PM
rangcrx's Avatar
i modifed my b16 oil pan cut out one tray and used my b16 oil pick up and a tube bender and bent it WITHOUT closeing the tube then cut the legs short and drilled a hole for the screws
i love AUTOZONE
Old Jan 9, 2005 | 10:00 PM
rangcrx's Avatar
BUT you do need gsr/typeR bolts or me im useing the gsr arp bolts
i love AUTOZONE
Old Jan 9, 2005 | 10:24 PM
mtber's Avatar
