Spark Plugs
Old Jan 8, 2005 | 06:30 AM
JDMBlackGSR's Avatar
Gators Bitches!
Default Spark Plugs
So after running the car for like 3 days the spark plugs are full of carbon. What does this mean beside needing a tune? More or Less Fuel Pressure? Something else need to be changed?
Old Jan 8, 2005 | 07:11 AM
Sabotage's Avatar
slash
is the plug the right heat range? make sure your air filter isnt clogged......could also be a problem in the fuel system or engine management or ignition.
good luck!
meows meows
TRick Squad Member #3
VicPrez of IttyBittyTittyCommittee
Old Jan 8, 2005 | 07:17 AM
Gators Bitches!
i am sure they are the right range, they are platinum
2003 Accord EX-L V6
Interior
'07 Shift Lever♦Diode Dynamics Stage 1 LED's
Exterior
HFP Front & Rear Lip♦Limo Tint♦LED Smoke Tails♦Yellow Fogs♦8000k Low Beam HIDs♦LED Reverse Bulbs♦Gunmetal Stock 7 Spokes
Suspension
Rear Lower Tie-Bar♦Front Strut Bar♦TL-S Rear Sway Bar♦MOOG Rear Endlinks♦HFP Suspension♦Ingalls Camber Kit
Engine/Performance
Nokya Battery Tie Down♦Spoon Radiator/Oil Cap♦Skunk2 Clutch Cover♦Stainless Brake Lines♦TL Engine Cover♦RV6 J-Pipe & Test Pipe♦Short Ram Intake
