Tial wastegate sizes...what's the difference?
Old Jan 6, 2005 | 10:03 PM
The Spectacle's Avatar
Spent more money than you
Originally posted by mtber
Yes it does, buy a tial 38mm & have a nice day.
you haven't explained anything. if you can help me out please do, otherwise I'm still waiting for a logical answer
Racing Integration
LHT Performance
My tuner is named Alpha
Old Jan 7, 2005 | 04:41 AM
pheobo's Avatar
Boom Chackalacka
Yes, The gases are released throught the wastegate before it its the turbo. There is no minimum boost since you have to go through 1lb to get to 5 and 10lbs of boost.
The difference in the WG isn't only the spring, but the size of the opening on the WG. You can think that at 25 lbs on a T77 is flowing LOTS of air. Once pressure reaches 25lbs the air going through the manifold need to maintain spool but not increase it. The wastegate opens and allows that air to go via the dumptube.
If your WG is to small, when it opens (or doesn't open all the way or is to small for the amount of air needing to be relased), it will not allow the correct amount of air out the tube. This will send the "extra" exhaust air through the turbine causing a boost creep.
The good thing is that 38mm will work fine on your B16. If you need more you can put a stronger spring on it and you'll have plent of waste available for a B16.
O... and it usually knows how much gasses are needed to go to the turbine instead of WG by the boost preasure.
This is only my understanding, I'm no expert.
200+ MPH Club
1000+ HP Club
Old Jan 7, 2005 | 04:57 AM
thanks, that answered a lot of questions. one last one...what does it mean that the spring is 7.5psi (the 38mm Tial)? I've also heard of 10psi and 12psi...what's the difference there?
Racing Integration
LHT Performance
Old Jan 7, 2005 | 06:36 AM
  #17 (permalink)
PoppaSmurf's Avatar
Chowdah-head
jeff, im gonna call you out on this one, you can run well into the 500's on a 38mm, ron was making 540 on one, Joe Bucci (mitsubucci) made around 500'ish at the wheels with one, so no, after 400 hp you dont need a bigger gate....btw....the rest of the info was correct
Poppa J. Smurf
Old Jan 7, 2005 | 07:17 AM
  #18 (permalink)
Rich's Avatar
Old School.
Horsepower doens't mean dick, it has to do with how much boost you are going to run on X motor with Y turbo. If you have a huge turbo, and you want to run 10 lbs of boost with it, you're going to need a big wastegate. If you have a medium size turbo and are going to squeeze every gasp of air out of the thing, you don't need a big wastegate.
You may know who we are, but we KNOW who you are.
Old Jan 7, 2005 | 07:29 AM
  #19 (permalink)
pheobo's Avatar
Boom Chackalacka
Originally posted by Cronic
*shakes head* I don't even want to go into how odd some of this information is...
If you have a 5psi spring, you can NOT go lower then 5psi, ever. Unless you make a way to divert more gas into the chamber, such as disconnecting the mechanical part of the gate.
Um... NO... You can go under 5lbs. The Wastegate just wont open hence the driver will not be able to hold constant boost under 5lbs at WOT. 1-4 do come before 5 <--- just being a smart ass
Yep there are some odd things in my post let me point some out.
1.) The Tial 38M would be enough for his B16. This may have been interpreted as being said for any B16... I meant for his B16 with his goals. -- I do believe you would be hard pressed to find a "non-professional" B16 that requires more then a 38, and if it does a larger springs should do it .... Since the opening should be big enough to bypass the amount of air needed to prevent more boost or surge.
2.) I said the wastegate opens based on boost pressure. I should have said manifold pressure?
I would appreciate it if you corrected me in anything I mistate. I'm new and am learning too. I even put a disclamer hoping that someone would let me know if any of my understandings are wrong :bbb:
