cheaper honda bearings? were to go?
Old Jan 6, 2005 | 08:29 AM
juiced2ndgenteg's Avatar
Default cheaper honda bearings? were to go?
I've paid $12+ a half at palm harbor honda, and about the same at ferman acura.:bbb: I need a set for my car now. where can I get them for less than $200 a set. I already have 1 rod and 1 main. for an LS shortblock(hehe).
Old Jan 6, 2005 | 08:35 AM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
i paid a little under that the last time i bought bearings but i got employee discount....ask aroudn and see if someone will hook u up.
~jake
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old Jan 6, 2005 | 08:37 AM
JDMBlackGSR's Avatar
Gators Bitches!
i have some bearings from my gsr, not to sure if you want new or used. Ill check tonight and see if it is a full set.
2003 Accord EX-L V6
Interior
'07 Shift Lever♦Diode Dynamics Stage 1 LED's
Exterior
HFP Front & Rear Lip♦Limo Tint♦LED Smoke Tails♦Yellow Fogs♦8000k Low Beam HIDs♦LED Reverse Bulbs♦Gunmetal Stock 7 Spokes
Suspension
Rear Lower Tie-Bar♦Front Strut Bar♦TL-S Rear Sway Bar♦MOOG Rear Endlinks♦HFP Suspension♦Ingalls Camber Kit
Engine/Performance
Nokya Battery Tie Down♦Spoon Radiator/Oil Cap♦Skunk2 Clutch Cover♦Stainless Brake Lines♦TL Engine Cover♦RV6 J-Pipe & Test Pipe♦Short Ram Intake
Old Jan 6, 2005 | 08:44 AM
thanks but, I need new! its a SLEEVED LS block...
Old Jan 6, 2005 | 08:45 AM
Gators Bitches!
ok, no prob, just thought would throw that out to you
2003 Accord EX-L V6
Interior
Exterior
Suspension
Engine/Performance
Old Jan 6, 2005 | 09:01 AM
Bill's Avatar
Livin' in Seattle
Have you tried www.hondrparts.com?
I used to buy a lot of parts through them. Also Len on Honda-tech.com had some pretty damned good prices on parts and I believe that was through a Naples dealership so it's fairly close.
Old Jan 6, 2005 | 09:03 AM
60-1EK's Avatar
Engineer at the source
www.acuraautomotiveparts.org
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Jan 6, 2005 | 10:28 AM
24-7's Avatar
Civic Racing eXperiment
Honda
Old Jan 6, 2005 | 10:36 AM
4dorteg's Avatar
Allan works as well
acl $99.00 complete set
TR salesman..........
Old Jan 6, 2005 | 10:37 AM
4dorteg's Avatar
Allan works as well
and before flame fest being alot of top builders use these bearing, its an option
