Cleaning gas lines out.
How do you clear all gas lines out to get rid of crappy gas?
i guess the easy way would be maybe undo the return line from engine bay and under the car drivers side,and use a aircompressor and blow it wil 90psi i think that should do it : o) and then repeat for feeder line but if you have time take them out very easy if you have alot of time to remove parts
i love AUTOZONE
i love AUTOZONE
Guest
Posts: n/a
Yeah, there is no easy way. Empty the gas tank out. Disconnect return line from tank, put in a couple gallons of good gas, and run it all out by priming the pump several times until gas is gone.
That would logically seem the best way to me.
yeah cronic's right, but run the return line into a container to catch all the nasty gas coming out. just put some good fuel in the tank and just keep runnin the fuel pump till the line is clean
NO EXCUSES for my lil FWD! Cmon RWD's n AWD's, lets DIG!
STEISS RACING all the way
HONDA ENGINES from oem to EXTREEM
www.myspace.com/streetracin_cwby
http://www.facebook.com/#!/profile.php?id=1433200141
