vtec help
Old Dec 28, 2004 | 02:06 PM
tanner belew's Avatar
Default vtec help
I got a gsr swap for my integra but my vtec is not engaging. everything is in working order its all wired up to the ecu right and my friend said that its something between my ecu and the dash can anyone got any ideas on what it is or how to fix it
hanh
Old Dec 28, 2004 | 03:02 PM
rangcrx's Avatar
engine building &best
you sure the vtec is grounded? you sure your even useing a vtec ecu?
i love AUTOZONE
Old Dec 28, 2004 | 03:03 PM
mtber's Avatar
You need to check for continuity between the engine bay vtec wireing & your ecu to rule out wirng issues.
Old Dec 28, 2004 | 04:59 PM
it was checked for continuity and its fine
hanh
Old Dec 28, 2004 | 05:27 PM
mtber's Avatar
Check for MIL:
http://www.phearable.net/tech/
Old Dec 28, 2004 | 05:47 PM
na200whp's Avatar
Powered by BOOST
like mtber said check for codes . things like map and tps can cause vtec not to work.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
Old Dec 28, 2004 | 06:24 PM
already checked the codes nothings wrong
hanh
Old Dec 28, 2004 | 07:01 PM
The Spectacle's Avatar
Spent more money than you
well something is wrong
Racing Integration
LHT Performance
My tuner is named Alpha
Old Dec 28, 2004 | 08:42 PM
rangcrx's Avatar
look on the ecu and tell use the letter/numbers on it when you put the motor in did you change the ecu or keep the same one?
i love AUTOZONE
Old Dec 29, 2004 | 06:15 AM
juiced2ndgenteg's Avatar
put 12v to the vtec solenoid activation wire at idle, if the soleniod clicks but nothing happens(vtec didn't engage), you have a mechanical problem(rocker arms or LMA's) . if the solenoid clicks and your car starts idling rough and almost stalls(vtec engaged) then its something electrical. if your solenoid dosn't click then get a new vtec solenoid. the vtec solenoid should "click on" when you put 12v to the activation wire. this should help you figure out what is wrong.
