mini me ?
ok i know that to run a z6 head on a obdIIa car ( 96-98 ) i need to run a jumper harness so the car will be obdI like the z6 head. my question is, can i run the z6 on a y8 dist and ECU to avoid getting a jumper harness? also on the mini me (block being used is y7) do i buy the head gasket for the head im using or the block?
thanks
kris
thanks
kris
the y8 distributor won't bolt up the arms are to long. all you have to do is rewire it just match up the color of the wires it's simply. and yes you can run the ob2 ecu and harness. if you near clearwater i can help you i have a mini-me in my hatch.
that's president hussein obama to you :gordy:
its not ready to go on yet, i still need to put the skunk cam and aem cam gear on it. do you know what head gasket to use? block or head?
i would worry about gettibng it running first cause mini-me always have problems that need to get fixed ie timing, vacuum leaks, to much oil pressure. then go obd-1.
and chris if your gonna say too much stop buying shit u dont need and u can get a b series swap sell ur mount kit sell ur intake manifold and the head and if u got the can and can gear use that money for the swap. call me
DONT SLEEP's penis tastes soooooo good
