wastegate question
Old Dec 19, 2004 | 01:23 PM
89crxsir's Avatar
Question wastegate question
got a turbonetics deltagate mark II wastegate from a guy, can anyone tell me how to adjust boost pressure on it??? can't find anything on the web thanx
SEE NO EVO HEAR NO EVO!
If i put half a tank of Shell V power, and half a tank of Chevron with Techron. Will i get v-tec??
Old Dec 19, 2004 | 06:43 PM
Turbo GSR Civic 95's Avatar
loosen the nut in the center and tighten down the screw but that will only get you a few lbs so it depends on what size spring is in it usually they are like 5-7 or 11-13 so to go more than what the springs are rated at you need a boost controller
John
Old Dec 19, 2004 | 06:51 PM
89crxsir's Avatar
we tried that.....screwing it in and out....boostgauge never left 20psi thanx
Old Dec 19, 2004 | 08:22 PM
well if its hitting that high is the wastegate even opening? where do you have the vaccuum line hooked to the top or the side?
John
94lsteg's Avatar
BOOST IS BETTER!
haha ....wow, sounds like your missing the spring there cheif...or your not screwing it out enough....the bolt should be sticking out...but im guessing you did that...so the guy who sold it to you ripped you off and you need to find a spring for it...
Old Dec 20, 2004 | 05:47 PM
89crxsir's Avatar
it is hooked up at the side, we tried adjusting it in and out.... boost never changed. plus i got it for free can't beat that
