buddy club cams spec3 VS spec4
i had my car dyno tuned back in November w/ a set of Buddy Club spec 3+ cams. At the time it was my daily driver and wanted more useable power .I was in search of a cam that would give me the most midrange out of my setup w/ out having to rev it past 8000rpm. the bc3+ seem to fit the profile and the price was right. the car ran really well on these cams and went 12.60's on slicks w/ 108 trap speeds.
here is the bc3= dyno plot
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
K series on crack
S D M
thats sweet. i wish i can hit 12's all motor but i will be happy with 12's on the spray. what kind of compression you running if you dont mind me asking?
Proven Power Dyno Services
A++
Built not Bought
A++Built not Bought
nice numbers man, gotta love the buddy club, wish i could do numbers like that
||=|| ((O)) ||\\ || |D) //-\\
DB2-SOLD!
Dc5 Type-S-SOLD!
97 civic 4dr-SOLD!
05 civic 4dr EX SE-SOLD!
08 Acura TSX_ 6mt
DB2-SOLD!
Dc5 Type-S-SOLD!
97 civic 4dr-SOLD!
08 Acura TSX_ 6mt
the week after the last TR track day i had a set of the new BC spec 4 cam on my door step . the car was no longer daily driven and i needed more top end in the power department. me and jason (ek60-1) went to the same dyno as the previous tune and with no other mods other than the cam swap were able to make some nice top end gains. the car lost no midrange or tq going w/ the larger cams.
bc spec 4 plot
bc spec 4 plot
K series on crack
S D M
K series on crack
S D M
here is an over lay of the two plots . this will give a better idea of the gains of the bc4's
K series on crack
S D M
K series on crack
S D M
my set up ---
b20 vtec (12.5 to 1) compression
ported b16 head
skunk2 intake manifold
headertech header
and alot of extras
ported b16 head
headertech header
and alot of extras
K series on crack
S D M
K series on crack
S D M
do you think it would be to high of compression if i was to put civic type r pistons in my car? and also what about piston to valve clearance?
A++
Built not Bought
A++Built not Bought
it should be fine but you will have to clay the engine to see how much you can adjust the cam gears.
K series on crack
S D M
K series on crack
S D M
buddy club 4's
intake 306 duration, 12.3mm lift
exhaust 302 duration, 11.8mm lift
buddy club 3's
intake 304 duration, 11.59 mm lift
exhaust 294 duration, 10.71mm lift.
these spec are at 0 mm lift. not the standard readings at 1mm lift.
buddy club 3's
K series on crack
S D M
K series on crack
S D M
