ls rods in d series block
is this possible? if so does it throw the ratio off alot? just thinking these rods (if they fit) would offer strength in a boosted d series? then again i could be really wrong and look like a fool for posting this. let me know guys.
yea they fit, not sure what it does to rod/stroke ratio and you need a bushing kit to put them in....IMO i say just fork out the money for some eagle rods.
92 240sx Vert-Drift car-CA Powa!
91 Civic Si-Minty Fresh-Boosted B20/Vtec
01 IS300-DD beater-2JZ no shit
they will only fit in a d16 and you have to cut a notch out of the bottom of the sleave.
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
I asked the same question on H-T. They told me that a machine shop would have to do a little work, but I should use B-16 rods, if not aftermarkets. The B16 are stronger, but I'm sure the LS rods are stronger than D16 rods...
My next set-up will be a LS/B16 rod with a D16z6/aftermarket piston.
86' snapper electric powered lawn mower.
95' F-350 crew-cab powerstroke 5-speed 21.63mpg
03' G35 6-speed coupe. Grey on black.
02' wranlger apex edition with EFI 5.0L 302 SBF. 5.5'' lift, custom 4-link 8.8 in the rear, high pinion D30 front with locker.
A wise man once said, " I didn't wash my hands b/c my D**K is cleaner then ANYTHING, in that bathroom"
LS rods are the same length as D16 rods (137mm). your rod ratio will be unaffected.
B16 rods are too long. the LS rods are stronger than D16 rods.
Shawn
The answer to your question is sqrt(pi)
Shawn
so what is it about machining the bottom of the sleeve in a notch?
i've never head of b16 rods going into a d16 block.
yea the ls are the same and a bit stronger. if you are staying under 200 hp (aren't they rated at that?) you are good to go with the d16 rods.
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
well as the crank shaft turns and pushes the rod up it will hit on the bottom of the sleeve because it is thicker or wider however you want to look at it. so to make sure it doesn't hit you have to cut a notch or file a notch on the bottom of the sleeve for it to work.
If you can, use the D16 rod. The LS rod maybe stronger, but its also heavier.
Re-balencing is a must.
I'd take a properly tuned D16 to 250hp without too much worry, but anything over that, and I'd have a "back-up plan" ready.
I'd trust the LS rods for over 300hp.
Really I think the D16s have a problem with breaking pistion rings or pistons. broken rods are more a " untuned propblem " IMO.
