stuck crank bolt
go to habor frieght and buy the largest impact they have.
The Myspace Page
Hero's arent born there american
made.
Aco. 53rd CSB LTF - TMT - 1st SQD
Afganistan Tour 2005 - 2006
- Its Game Time -
The Myspace Page
made.
- Its Game Time -
Does the inside of your crank pulley have a hex pattern, if so there is a tool to put in it to brace it. Then you can use a large cheater bar (I use a large jack handle) to break it loose.
Actually Your Right But thats a Honda Only Tool. Its a Open End Hex Wrench with a 3 foot handle. its used to hold the crank still or if you were smart if the motor was out Put 2 Flywheel bolts in and put a Breaker bar between them and hold it still !
the problem isnt holding it still I took off the oil pan and wedged a screw driver in between the counter weights and the block girdle to stop it from moving. The bolt doesnt budge.
Wedging something in the counterweights is not a very safe practice. You could distort the shape of one of the Main Bearings and cause yourself a problem in the future. Also , the tool to hold the crank pulley can be purchased off of most tool trucks, if you know someone that works at a shop you can have them get you one. I am pretty sure mine is Bluepoint (Snap-on). If you don't know anyone at a shop, go to one that does alot of work on imports and the techs will most likely have one, and with a generous deposit maybe let you use it. Then you just need a bigger cheater bar and it will definately come loose, unless you have girly arms.
ive done some janky shit i put the socket on the bolt with a breaker bar and angled it toward the ground and lowered the car on the breaker bar so the weight of the car broke the bolt looose its ghetto but worked for me
BFK for life, forever, get your dick sucked
damn, if only they were open, and w/ a hundred bux..
