kill switch
Old Nov 12, 2004 | 06:29 AM
BERT-O's Avatar
yO!
(+) or (-) wire on the fuel pump. Run a toggle switch on the ebrake handle switch. Say if that thief takes your car, he must release the brake handle. If he doesn't hit the switch again, car won't start.
You like that huh.
Old Nov 12, 2004 | 07:17 AM
Evangelion's Avatar
Couldn't you also wire it to the clutch pedal. You know, when you depress the clutch pedal it hits that switch that allows the car to start. Find that wire and make a switch for it.
Old Nov 12, 2004 | 09:34 AM
lead's Avatar
I'm Awesome
just install an alarm
Alarm Crazy!
|| 1994 Honda del Sol vtec || B16a2 || 2 engines in garage one in car w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Old Nov 12, 2004 | 10:33 AM
zcnitroso's Avatar
Yeah, easiest way, buy an alarm and tell everybody that you bought the GPS Tracking System from Vyper and you can track your car anytime and anywhere in USA (trust me, they are not going to touch your car) and just in case this system cost about 800.00 and is separate from the alarm. And then . . .
I miss tampa fl
Old Nov 13, 2004 | 06:09 AM
Frankie Figs's Avatar
Too Much is ALMOST Enough
who wants to steal ronald's fun house?????
Old Nov 13, 2004 | 03:06 PM
lsrex212's Avatar
clutch pedal switch is a bad idea....most 5sp cars require you to hold in clutch i think...mine does not because it used to be auto...i like the disguised idea...has to be an easy to get to switch for convenience...put a switch by the trunk/gas door levers that way its not so niticeable when you hit it...but a good alarm would do fine as well...and a big gun...
Old Nov 13, 2004 | 03:54 PM
  #17 (permalink)
alternativeauto's Avatar
Here's an easy one. Unbolt your main relay and let it hang down (should not hang below dash in plain veiw unless your harness is extra long). Just unplug it and take it with you. Easier than taking ECU with you because it is on the drivers side, and if you take the metal holder off of the relay it is small enough to not be an inconvenience. This should foil most theifs, unless they read this and bring one along.
Old Nov 13, 2004 | 07:07 PM
  #18 (permalink)
DirtyDave's Avatar
banned
Alarm !!! They have a BUILT IN KILL SWITCH ! called a starter kill ! and add a redundent relay so it has to reactivate BOTH to be hot wired !
Old Nov 14, 2004 | 07:50 AM
  #19 (permalink)
BigBodySmith's Avatar
Retired Street Racer
Here is a good site that tells you step by step on how to install a fuel cutoff switch...
http://www.courtlukens.com/cutoff_switch.htm
My Old Honda
