ITR vs the GSR water/oilpump
Old Nov 11, 2004 | 02:29 PM
TSX24L's Avatar
Default ITR vs the GSR water/oilpump
Is there a differnce at all in affecting anything using a gsr oil pump and water pump on a lsvtec setup? Iam sure it will see high rpms in the 9000 range. Just wondering if it would be ok to use for my setup. Compression should be around 11.8 give or take.
Also iam going to be putting my engine on a stand soon but need to know what size bolts to use?
Old Nov 11, 2004 | 02:32 PM
TSX24L's Avatar
One more question, will the ls crank be fine to use?
Old Nov 11, 2004 | 03:30 PM
99B16Si's Avatar
gsr and itr pumps are the same(obd2 at least) and it would be kind of hard to build an lsvtec motor without an ls crank, dont u think?
Old Nov 11, 2004 | 08:37 PM
2ndGenT3g's Avatar
u can get a itr water and oil pump from inlinefour.com water pump comes with everything u need belt, tensionor or u can jus get the pump
||=|| ((O)) ||\\ || |D) //-\\
DB2-SOLD!
Dc5 Type-S-SOLD!
97 civic 4dr-SOLD!
05 civic 4dr EX SE-SOLD!
08 Acura TSX_ 6mt
Old Nov 12, 2004 | 04:42 AM
smoke3's Avatar
Its a secret
B16A oil pump 53qpm
B17A oil pump 54qpm
B18B oil pump 53qpm
B18C oil pump 75 qpm
B16A water pump 140qpm
B17A water pump 140qpm
B18B water pump 148qpm
B18C water pump 148qpm
LS oil pump ---> ITR/GSR oil pump = straight swap + if you bore it out you'll get better performance?
LS fuel pump ---> ITR/GSR fuel pump = straight swap but after 1995 all Integra fuel pumps are the same?
LS water pump ---> ITR/GSR water pump = straight swap but you need to use an ITR/GSR drive belt because there are more teeth driving it?
from some where on ht i copied it a while back cause i was planning on swap water and oil pump on ls for my turbo setup
The Myspace Page
Hero's arent born there american
made.
Aco. 53rd CSB LTF - TMT - 1st SQD
Afganistan Tour 2005 - 2006
- Its Game Time -
Old Nov 12, 2004 | 06:09 AM
99B16Si's Avatar
all the obd2 replacement part numbers are identical for b series oil pumps
Old Nov 12, 2004 | 06:19 AM
BERT-O's Avatar
yO!
Originally posted by smoke3
[B]B16A oil pump 53qpm
B17A oil pump 54qpm
B18B oil pump 53qpm
eh.................lol
Ask the top 10 head Honda builders in the US, they will tell you the same thing!!!
ALL B-SERIES OIL PUMP ARE THE SAME, SAME SHIT, SAME PART, SAME FUCKING PART NUMBER.............FUCKING ALE
For those who are learning, ITR Oil pump is the same as the stock CRV, Civic SI ('99-'00), LS/GS/GSR/ITR motors. Yes, part numbers are different from '94-'95 due to OBD-2 on the later models. OBD-2 have the Crank sensors, whereas the OBD-1 don't have.
Old Nov 12, 2004 | 08:42 AM
Old Renegade's Avatar
Cool Runnings
good info but don't the itr flow better than b-16 or just mainly isn't it better? i know you say that all b series are the same. Juast asking..
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Nov 12, 2004 | 07:00 PM
TSX24L's Avatar
ok thanks for the help on the oil pumps and water pumps. What about a ls crank vs a crv crank?
