Getting no spark
1997 civic hatchback CX. I have had no problems with my car. since ive owned it, except twice now ive lost the spark.
Its not the Distributer cap, plugs, or coil, they are all brand new. I smell gas, so i dont think its the fuel filter either... anything to help would be much appreciated.
like always with hondas cheack your rotor inside your distributor cap is it makeing a poping like its trying or you getting nothing
i love AUTOZONE
i love AUTOZONE
Im not getting any effort at all as far as it even trying... Im thinking that it may be the plug wires, they where hanging low and the heat from the headers might have got to them. I see some damage... But still wouldnt it try to start if it was the wires?
yes but unless all the wires went bad at the same time then you will at least get some pop from the good wires firing you might want to check your wireing or ecu
i love AUTOZONE
i love AUTOZONE
If your not getting any spark then it os more than likely the ignitor in the distributor. The fuel smell could be coming from you flooding the car the more you try to crank it over.
http://www.myspace.com/terry_ho
i opened up the cap and saw no damage to the ignition coil...and im definitly not pumping the gas all that much to flood it... i managed to get it started on three plugs but since ive messed with it a little more, im getting absoulutly no responce.. thanks keep it comming, i need this bad boy running, and now its getting personal
plus 1 on the ignitor. they short out very easly.
