top dead center sensor?
Old Nov 7, 2004 | 07:23 PM
b16-to-j30a1's Avatar
I've had better
Default top dead center sensor?
anyone know what this code means? I drive an acura cl 3.0
Mid-Life Sedan
Old Nov 7, 2004 | 08:12 PM
mtber's Avatar
Usually it has to do with the TDC sensor in your distributor.
For some reason when my old ls setup threw this code a new cap & rotor resolved the issue... Don't ask me why...
Easiest fix is to find a known working distributor for your vehicle & try it out
Good Luck.
Old Nov 8, 2004 | 03:14 AM
alternativeauto's Avatar
If the vehicle has a crank sensor, this is probably the problem. I have had a CRV at my shop throw the same code and after checking and testing a new dist., it ultimately came down to the crank sesnor. Look down by your alt. and see if you have a 2-pin plug that goes behind the timing cover, if so your vehicle has this sensor and it is very possibly your issue.
Old Nov 8, 2004 | 11:12 AM
I've had better
thanks guys....
Mid-Life Sedan
