Honda GX20 block?
Im watching car and driver, and they just showed something about a new block made by honda that makes 270 hp at the crank and 185 ft/lbs torque (built for nitrous they said). im just wondering if anyones ever heard anything about it
FLeuro
TheCommision
FLeuro
TheCommision
* Designed and built with a coalition of the world's best components for indisputable performance and reliability
* Close-tolerance engine designed to produce 270 bulk horsepower @ 7,800 RPM and 185 ft./lbs. of torque at 6,000 RPM
* 3.307" (84mm) bore with 11.5.1 compression ratio
Each performance component has been custom made for this GSport engine. Includes DART machinery block, GSport Pro rods from Olive Racing, GSport Pro pistons from Wiseco, GSport Pro spec crank specially designed by Eagle, GSport spec cams and Mr. Gasket® gaskets. Stroke: 3.504" (89mm). Rod Length: 5.543" (140.8mm). R/S ratio: 1.58:1. Intake valve size: 34mm. Exhaust valve size: 28mm. Manufacturer's limited one-year warranty (short block warranty applicable to material and workmanship only). Short block engine is fully assembled and decked ready for final assembly. Shipped separately from factory. NOTE: SKU numbers ending in F are factory shipped and may take a little longer to reach you.
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
