camber kits questions
i was looking in to geting a camber kit, and i herd they are a pain in the ass to adjust and alighn, do they make camber kitsthat are bolt on and ready to use?if not what is a good camber kit to get that is some what in exspensive?
all that can be said is good luck with it. i have the ingells kit and on the rear it is just fine and easy to use but when it comes to the front it is another story. i had to go in with an air impact hammer and dent the inner fender wall just to get enogh clearance between the upper control arm and the inneer fender wall
Originally posted by CiViCBoY
Skunk2 front camber kits are nice
meows meows
TRick Squad Member #3
VicPrez of IttyBittyTittyCommittee
meows meows
Originally posted by Sabotage
i second that!.......i just installed my skunk2 camber kit and it was pretty easy.......
I still have to get the front aligned, But I have the Si dropped on it's Nutz and the Skunk2 still isn't rubbing the inner fender welded lip.
It was already adjusted from the previous owner, But still......No problems here!
yea the skunk2 would be better because the ingalls can get un even when you adjust them and it fucks up your tow bad and eats tires.
i think im gonna switch out my ingalls kit with a skunk2 kit because of this.
but if you use ingalls just find a shop that will do alignment and camber adjust ment on a lowered car then put the kit on and take your car there to have it properly adjusted.
-j
-j
well just a question i think that the skunk 2 kit is only for the newer like 92 and up guys. but if i remeber correctly they do not have anything for those of use that have the pre 92's. not to sure if this is true but let me know if i am incorrect.
