GE LSvtec conversion kit..
Old Nov 3, 2004 | 02:44 PM
TSX24L's Avatar
Default GE LSvtec conversion kit..
When ordering what bore size do I select? Iam buying through lightningmotorsports. It would be a ls block but iam using usdm b16 pistons. So would it be 81.5? I don't know?
Old Nov 3, 2004 | 02:52 PM
NChatch's Avatar
i stepped on my weiner!
depends on the pistons you have, on the top they will have a number like .25,.30 that is the overbore size,
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Nov 4, 2004 | 12:14 AM
mtber's Avatar
Personally I wouldnt buy a GE conversion kit because they dont usually come with an oem honda/acura headgasket.
I would buy each item I needed & use an OEM honda head gasket.
Concerning 1 up oem pistons, you can use a factory headgasket.
Acura only makes 1 ls (p75) headgasket according to my books...
They would list an alternate part number for an overbore headgasket if it was needed....
Old Nov 4, 2004 | 03:17 PM
TSX24L's Avatar
Iam using .25 os. But what size is the bore size if am using .25 over? whats a stock ls bore size?
Old Nov 4, 2004 | 03:53 PM
{{HEAVYDUTY}}'s Avatar
If you doubt me,try me!!!
81.25 is your size
