need a ecu
Why would you want to first of all?
However, I'm willing to try this just to give you your answer I have both cars sitting around . . . . but my guess is it will not work. . . . Will try after work if i have time.
no dx would be a dual point, this is why i dont think it would work.
i need to get a new ecu in 91 crx. Cause it starts most of the time. But it don't want to some times . I pull the ecu fuse and wait about 2 mins and it starts after 2 times of doing this. I want to up grade the ecu too.
:gotrice
:gotrice
mpfi ecu is not going to work right in a dpfi car.
Originally posted by 91b16si
if it runs it will run like someone shit in your cheerios
"Cause it starts most of the time. But it don't want to some times . I pull the ecu fuse and wait about 2 mins and it starts after 2 times of doing this."
This sounds like Main Relay . . however, if you really think it is the ecu then your pm5's are a dime a dozen . . . .
