Attn: Honda Techs OBD2 problem... Honda Odyssey
Old Oct 28, 2004 | 05:35 PM
GOTTI's Avatar
OEM Parts Specialist
Default Attn: Honda Techs OBD2 problem... Honda Odyssey
Well the ole family car tthe Honda Odyssey has a check ngine light...the tracktion control light comes on occasionally and i want to find out what the hell the problem is.
If there is someone that knows about the recall on the Transmission on them or to find out which VIN#'s have the recall or where to find them please let me know.
And if someone in Brandon or Riverview has a OBD2 tool and would hook me up that would be cool..
thanks
Paul
Old Oct 28, 2004 | 06:26 PM
GOTTI's Avatar
Old Oct 28, 2004 | 07:37 PM
SEEKERone's Avatar
Trialed for Treason
very common on the 99-01 odyssey is the egr port clogging.
honda extended the warranty on this until 8 year/80,000 mile.(or more if you ask nicely)
occasionally will cause the TCS(traction control) light to come on.
AUTOZONE used to check codes for free but i am not sure if they all do this still. if you can get it checked and the code is P0401 or P1491, then this is where your problem may be. (DO NOT LET THEM CLEAR IT IF YOU INTEND TO GO TO HONDA)
the repair involves removing the plenum, clearing the egr port, adding a pipe to prevent the reoccurance, and replacing the EGR valve itself.
as far as the tranny warranty extension, this applies to 99-01 odysseys and usually you will have a signifigant shifting problem if there was something wrong.
Old Oct 30, 2004 | 05:50 PM
{{HEAVYDUTY}}'s Avatar
If you doubt me,try me!!!
he said it
need a realestate agent contact me.
Run your car not your mouth!!
2006 GSXR 1000
1988 CRX SI "All Motor"
"not 4 long"
It's my dick and i'll wash it as fast as i want to!
Let me guess? You missed a gear!!!
FUCK BARNEY'S!!!!!!!!!!!!
