i just pulled spark plugs....
Old Oct 25, 2004 | 01:48 PM
djvtec5's Avatar
the next best thing!!!
Default i just pulled spark plugs....
i just pulled my plugs and they were drenched in oil is this bad???
Old Oct 25, 2004 | 02:21 PM
Ilicia's Avatar
I love Kiss0fjupiter!!!
Well its not good. Check your valve cover's spark plug gaskets.
Cronic (to un-named): Some people have nothing better to do, but to follow girls around who aren't interested in them, or bash others on a board. Either way, it's pointless, and down right stalker-like if you ask me.
Old Oct 25, 2004 | 05:13 PM
99B16Si's Avatar
spark plug seals in the valve cover are leakin homie
Old Oct 25, 2004 | 05:14 PM
Whaazup17's Avatar
check piston rings also
Old Oct 25, 2004 | 05:18 PM
Jay's Avatar
Jay
Janky
yea is the oil above or below the threads on the spark plug.
ex. is he socket getting oil on it when you got to take the plugs out??
if so its the spark plug tube seals if the oil is on the bottom of the plug i would be checking rings and or headgasket.
Aim: o JankyJ o
http://jankycrew.com
Old Oct 26, 2004 | 06:00 PM
MadisFastDSM's Avatar
tractionless
if its on the bottom u r having blow by which sux id start wrenchin asap
collision and refinising technician need bodywork/ paint call 727 776 7830
Old Oct 26, 2004 | 08:27 PM
djvtec5's Avatar
its on the part that screws in how would i go about fixing this??
Old Oct 27, 2004 | 12:08 PM
AnTman86T's Avatar
S130 love
Do a compression test. If the numbers are way off usually you have bad rings in the motor and time to tear it apart. I assume you are blowing oil out the back as well.
