whats the cheapest and most effective way to get this swap to work??
Old Oct 21, 2004 | 11:58 AM
kwikdelsol93's Avatar
Default whats the cheapest and most effective way to get this swap to work??
I bought this swap-
b16a JDM Motor and Head. With JDM Tranny and Hasport Motor mounts. Axels, Spindles, Wire Harnes, Intermediate Shaft, JDM ECU, Distrubitor, Every Sensor, Larger Radiator, Intake Manafold, Alternator Starter, Fuel Rail, Fuel Injectors. Basically its everything out of a 90 si hatch.
I want to know how I can put this in my 92 civic dx without spending to much money, and changing alot of stuff, What can I re-use? What should I buy? BTW I read alot of articles on this b4 posting. I just didnt get alot of questions answered. Can I re-use the Clutch from a cable tranny? Any info is really appreciated- Just dont say something unless you know what you are talking about.
Old Oct 21, 2004 | 07:31 PM
Old Oct 21, 2004 | 07:38 PM
MacGruber's Avatar
MaDe Of MoNeY
The transmission will not work unless you get a cable to hydro kit from hasport. Use your stock radiator. You don't need spindles. Im not sure about shift linkage.
Originally Posted by Z28ricer
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
Old Oct 21, 2004 | 07:47 PM
im planning on gettin the conversion, but imm gonna still need more info... Whos got this swap already done?
Old Oct 22, 2004 | 03:00 AM
m0nk3y's Avatar
pwns.
planning on switching to obd0? or setting the motor up for obd1?
Originally Posted by Lil Ze
Florida is the new Miami through and through.
Old Oct 22, 2004 | 05:37 AM
1fasthatch's Avatar
Traction Problems
You may have to do some rewiring on the harness!!!!!
www.artofspeedproductions.com
Old Oct 22, 2004 | 06:13 AM
I need someone to explain the best way to do the wirring. if i change it to obd1 ill have to buy alot of new parts...
Old Oct 23, 2004 | 07:23 AM
can anyone explain the whole rewirring thing?
Old Oct 23, 2004 | 08:13 AM
BERT-O's Avatar
yO!
cheap=more headaches than the IRS coming after you!!!
It cost money to have realiable and fast engine.
I would suggest someone like LHT performance to install the swap if you wanna run hydro tranny.
Good luck!
Old Oct 23, 2004 | 12:43 PM
Well bad news now. I need to do this swap sooner than i thought. I'm going with the cable tranny. what else do i need to change though.....
