Convert LS OBD-0 to Vtec OBD-0
you chop off the distributor leg that's would hit the vtec solenoid. You would be able to get one bolt on, then use a big washer to get the hold the other leg. It should only be used as a temporary solution. It'd work fine, but just ghetto.
The most overused word to describe an import: CLEAN. Every f****** car is so CLEAN.
