Manual Steering Rack on a Integra
Too Much is ALMOST Enough
on
I am building a 4dr GSR teg and I was wondering if a Civic manual rack will fit in the teg, cuz I cant run the power steering pump with my underdrive crank pulley. I saw someone who had conected the power steering lines together and filled it with fluid and said it steered just like a manual rack car, does this work?? Dont flame me for building a 4dr teg instead of the hatch.
Thanks
Thanks
A civic rack = shitty turning radius.
Convert your PS rack using some simple fittings:
http://honda-tech.com/zerothread?id=184202
There are plenty of ways to convert a p/s rack using bypass methods... Which one you want to use is up to you.
lines are cut on my integra have been that way sinse i got it havent had any problems
