del sol turbo kit
Old Aug 30, 2004 | 01:58 PM
jeffronismo's Avatar
Don't be a quitter...
Default del sol turbo kit
Hey guys. I have some ?'s on honda turbo kits.... What are the different turbo kits that would work with a 93 del sol si? About what would this cost? How would you go about tuning it or rebuilding for the safest use and drivabilty. Daily driver. If u cant tell , i'm not real into hondas- this is my sisters car I am talking about. Thanks
Originally Posted by satanshatch
"If it's got tits or wheels you're always going to have problems with it" - My father
Old Aug 30, 2004 | 02:20 PM
Josh's Avatar
Dr. Doom
greddy makes a nice kit, pretty affordable than most, and comes with pretty much everything you need besides dyno time and a good tuner
Old Aug 30, 2004 | 03:40 PM
98TRDCam's Avatar
iron lung
you can compare a couple kits here.
http://www.turbo-kits.com/del_sol_turbo_kits.html
Old Aug 30, 2004 | 05:30 PM
alright, thanks guys
Old Aug 30, 2004 | 05:31 PM
just curious, how does the whole vtec deal work with forced induction?
Old Aug 30, 2004 | 05:47 PM
kender's Avatar
gadget man
It just runs a more radical profile for better flow at high rpms. simply if you could take the cam out of your z and swap it to say a stage 2 or 3 at a set rpm while the motor was running, you would have the same effect. the low rpm profile just makes better economy and a smoother idle at low rpms.
vtec good : boost good boosted vtec
U.S.S.A Crew Member #001
Old Aug 31, 2004 | 05:48 AM
pressuredsol's Avatar
Pleasure the do me
jeffronismo-pm'd
Old Aug 31, 2004 | 11:33 AM
SickOfAlltezzas's Avatar
ALUMINUM POLISHER
if its obd1,id ask some of the honda guys to help you.farmer floyd will sell complete ls swaps with mounts and all for like 650.spend another grand or so on re-building it.youd prolly be better off all motor for a daily driver
Originally Posted by 240Cyanide
TR's better anyways.. where else could you find all this variety of assholes, drug specialist, and pedo's? not on that gay dsm site!
Old Aug 31, 2004 | 05:03 PM
kender's Avatar
gadget man
all motor, NO. as a daily driver and to get the same power a turbo would give all motor would have more intense tuning than a 8psi turbo, compression would be so high you would be too close to not being able to run on pump gas ( you could still do it but it'd be dangerous). and the tight tolerances on everything would be a headache and you'd almost have to pay someone else to do the work. whereas a turbo can be installed by alot more of the d.i.y. types and without the special tools needed for all motor. for what you are shooting for a good turbo kit like the greddy, and 8psi will do just fine on pump gas and add 60 to 80hp.
