Transmisson problems help
Old Aug 30, 2004 | 06:24 PM
60-1EK's Avatar
Engineer at the source
Mainshaft/Countershaft bearing. Happens all the time. Try the fluid fix first, then open the tranny up and look at the two larger bearings. You will see it right off if the bearing has fallen apart or is real sloppy.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Sep 1, 2004 | 04:47 PM
Hybrid Crx Si's Avatar
Holding Monster
i had a bad intermediate shaft seal that leaked like crazy and when my tranny would get low 5th gear would slip out... never had a problem with any other gear than 5th though..
"wear your lifestyle"
www.venndk8.com
www.facebook.com/venndk8
Old Sep 4, 2004 | 03:59 PM
jdmguy86's Avatar
well i did the fluid and it is still doing it but not nearly as muc.....????
Old Sep 4, 2004 | 04:07 PM
Holding Monster
probably bad syncros in that gear... DOH!
www.venndk8.com
Old Sep 4, 2004 | 04:30 PM
60-1EK's Avatar
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Sep 5, 2004 | 06:50 AM
mustwonder's Avatar
GY-16P
does it grind bad or anything when going into that gear.
probably the fluid like every1 else says
Old Sep 7, 2004 | 07:42 PM
  #17 (permalink)
zlaja_gsr's Avatar
Sounds like a bearing problem. Happened with mine too. Ordered all the bearings from honda. New tranny for 150 hell yeah.
