White smoke/overheating
Ricestang 5.SLOW
sorry i had to say it LOL
if you want a 2 layer or single layer head gasket i would just hit up a local performance shop and ask them what they got and recomend. probly gonna cost more
Originally posted by civicvxhatch
Whats the best head gasket that i should get that may also Raise my compression a little bit.
so in short it's a good idea to get it decked and while it's there i would get it shaved 25k while it's off you know....
art
IM IN VA BITCH!!!!!!
www.rccustomz.com
www.rccustomz.com
Originally posted by art
just while you have the head off take it to clearwater cyl. head and get 25k shaved off it and pop it back on...it's very light head work but a nice diffrence and cheap as well if you try and get a gasket to raise the comprestion you will spend more than you get out of it but with a simple shave of 25k you will put your cyl. psi at around 200-210psi per cyl. you need to have the head decked anyway if it has had a blown head gasket, and let me be clear you dont have to get it decked but it's a good idea to,
art
art
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
K series on crack
S D M
true the car do's run just a bit more ruff but I myself realy dont mind it....but a ACG will help put it back a hair, it will be out by about 1/2 a tooth or so....and if you deside to do any P&P work or oversized valve
s you want to look into uping your fuel supply a bit
but anyway keep us uptodate I alway's like to see head work done to the VX it's an interesting head it has smaller valve's but the chamber fill make's up for it the flow of the VX head is a bit slower but I but still a very intersting head to build
art
art
www.rccustomz.com
www.rccustomz.com
Janky Crew Productions
