question on building a 1.7 gsr
Old Aug 21, 2004 | 11:49 AM
Purpwr's Avatar
Default question on building a 1.7 gsr
just bought a 1.7 gsr shortblock........im going to build the motor for turbo. but not sure what to use........what is a good head to put on there and what kind of pistons and rods are good.......i want to go low compression cuz i want to put around 10 or 11 psi...........any suggesions will help..........thanx
sdsd
Old Aug 21, 2004 | 12:50 PM
Jay's Avatar
Jay
Janky
i would use a b17 gsr head if you can get one if not maybe a 1st gen b16 head or shit any had
you going to use stock internals or some forged goodness.
-Jay
Aim: o JankyJ o
http://jankycrew.com
Old Aug 21, 2004 | 01:48 PM
Purpwr's Avatar
thanx for info but what do u think that will cost me(for the rods and good pistons)so i dont blow my engine. Also is the stock gsr crank good to use or should i replace with a better one
sdsd
Old Aug 21, 2004 | 03:33 PM
99B16Si's Avatar
the factory bottom end will hold 280+whp without any issues as long as it has a good tune of course. any b series head will do the trick, id personally go with a type r head if i had the money if not id just get a b16 and throw in a set of ITR or GSR cams with a good titanium valvetrain and free-flowing manifold.
if youre putting forged internals in it and are only looking to make moderate power id go with a set of eagle rods and pretty much any forged piston will work(CP, JE, wiseco, arias, etc) just do some research and see which one you feel most comfortable using.
the factory b series cranks will hold 700+whp without any issues so i wouldnt worry about that.
the rods will cost ~$300
and the pistons about ~$500 w/ rings
dont forget youll need new bearings too
Old Aug 21, 2004 | 03:50 PM
Purpwr's Avatar
thanx for the info........so its safe to use the stock bottom end as long as i dont boost the hell out of it......also i have an itr intake manifold. will that match up to a gsr head or a b16 head
sdsd
Old Aug 21, 2004 | 05:45 PM
99B16Si's Avatar
b16, b17, or b18c5 head only
Old Aug 22, 2004 | 12:24 PM
MugenR's Avatar
I have a B20a crank for sale, which would make a healthy improvement...that is if your gonna buy rods and pistons.
scott
09 Pontiac G8 GT
08 S2000 CR (sold)
06 Sti (sold)
98 ITR (sold)
88 civic 4 door (sold)
95 Mustang GT (sold)
87 LX 5.0 stang (sold)
LHTPerformance.net
Old Aug 22, 2004 | 05:07 PM
Chris111's Avatar
member
the stock b17 gsr is pr3 head
Chris
