no vtec no speedometer
Old Aug 18, 2004 | 06:03 PM
civicsk8er's Avatar
Got Midori??
Default no vtec no speedometer
I just put a gsr tranny on my b16 cuz i blew the dif on the 16.The whole speed sensor on the tranny blew clean off the housing wit a see through hole in my tranny. I swapped the tranny and plugged everything back up and went for a test drive. For some reason my speedometer wasnt workin and vtec wouldnt hit, but when vtec did hit (which for some reason not at 5800 where it should be) my speedometer would work. Like once or twice everything worked perfect. Now my speedo doesnt work at all and neither does vtec. I pulled the clip that connects to the solenoid, and the white piece inside the connecter fell out, I tried pluggin it back in, it would slide but there would be no click noise like it used to make.
Any advice on how to solve this problem??
Thanks
Crown Vic
Old Aug 18, 2004 | 06:58 PM
99B16Si's Avatar
get a new plug/sensor(whichever is broken). vtec relies on several sensors to engage correctly, the VSS is one of them
Old Aug 18, 2004 | 07:04 PM
rms13's Avatar
well im gonna borrow my friends vtec solenoid and the sensor that plugs into it. if it aint that, what other sensors does vtec rely on. plus how come my speedo isnt workin??
Old Aug 18, 2004 | 07:15 PM
ElektroBass's Avatar
YOU WONT!
who needs vtec, its overrated hope u get it runnin soon hinch
Let The Good Times Roll
Subie Life!
Old Aug 18, 2004 | 07:20 PM
91b16si's Avatar
the speed sensor on the tranny is most likely bad, vtec wont pop if it doesnt detect a speed ,because you have do be rolling for vtec to hit and if the sensor isnt working the ecu thinks the car is still
BFK for life, forever, get your dick sucked
Old Aug 18, 2004 | 07:45 PM
civicsk8er's Avatar
Got Midori??
r u sure it aint the sensor on my harness cuz when my dif blew on the 16 it blew it clean off so maybe it could of zapped it or damaged it cuz the gsr tranny i got is clean
Crown Vic
Old Aug 18, 2004 | 08:10 PM
91b16si's Avatar
check the wires on the harness if thats ok then change the sensor
Old Aug 18, 2004 | 10:47 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
its your VSS.... trust me..... it has all the symptoms of a bad vss, and you should know this man ....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Aug 19, 2004 | 07:35 AM
civicsk8er's Avatar
Got Midori??
r u sure its my vss cuz say everything was workin rite and i unplugged my solenoid my speedometer is still gonna work just no vtec u kno what im sayin.
Crown Vic
Old Aug 19, 2004 | 08:36 AM
mustwonder's Avatar
GY-16P
hope you get it fixed soon havent heard any vtec around my corner at 1 in the morning in a while.
