cutting windage tray for more oil,good bad?
Old Aug 11, 2004 | 09:48 PM
rangcrx's Avatar
engine building &best
Default cutting windage tray for more oil,good bad?
i want to be able to take my Lsvtec to 9-10 but dont want to worry about oil and i new with my b16 it wa so easy with the oil squarters covering it but of course lsblock does not have it so im thinking if i cut 1"by2" around each rod will more oil cyclone up or will it just slow me down i have a 8Lb flywheel and 1Lb pully so much stress on the crank is ok let me no anyone
Old Aug 11, 2004 | 11:11 PM
quicksilver EK's Avatar
The one punch machine gun
that is dumb,rev it to 9 anyway,an i doubt the cams youll be using would make much power past that.
97 ITR-Mugen Equiped
04 Honda 600RR
Old Aug 12, 2004 | 03:21 AM
NChatch's Avatar
i stepped on my weiner!
windage tray is to stop oil slosh not to prevent flow
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Aug 12, 2004 | 05:33 AM
Bill's Avatar
Livin' in Seattle
You should really figure out what the purpose of a part is before you go hacking it up. The purpose of a windage tray is to reduce crank drag. Cutting holes in it isn't going to "cyclone" oil up into the cylinder bores.
Old Aug 12, 2004 | 06:37 AM
99B16Si's Avatar
oil pressure is not stopping you from revving to 9k. if u really want more oil pressure try shimming the oil pump, but like i said its not really necessary at all as the factory gsr oil pump is pretty good as it is
Old Aug 12, 2004 | 07:51 AM
rangcrx's Avatar
ok thanks for the input all just wanted to see what others would think
i love AUTOZONE
Old Aug 15, 2004 | 09:50 AM
KJ's Avatar
KJ
bored at work
If anything you would want to add a crank scraper. The oil squirters on b-series are for cooling not lubrication.
