Starting Problem....
Old Aug 11, 2004 | 07:02 PM
CRXsi887's Avatar
03 SVT FOCUS
Default Starting Problem....
Im not sure what the problem is and even how to tell you when it does it and when it doesnt....i have a 91 crx with a LS...for some reason it wouldnt start...nothing what so ever...the ecu would come on...and id turn the ignition and nothing...the ecu would shut off..so...we finally got it where the ecu would come back on...and then we push started it...in an earlier post i had a problem with it and i replaced the main relay...the relay is still making the same clicking noise...theres a couple cars around here with the same problem...if anybody knows how to fix it...or prevent plz help me
Old Aug 11, 2004 | 08:43 PM
delsolSI's Avatar
.....gas helps
-2003 Ford Mustang
-1986 Toyota Corolla GT-S
-1993 Honda DelSol Si
Toys:
-2003 Honda cr125r
-2003 Honda cr250r
Old Aug 11, 2004 | 09:30 PM
rangcrx's Avatar
engine building &best
its your starter meaning like you turn the key and shake the car to make it catch or check your ground/clutch wires
i love AUTOZONE
