im going from a d16 to a b16a2
does anyone know where i can find out what all ill need to switch over like cv axles and the like?
people try so hard to be someone there not when its so much easier to be your self!
try hasport.com, they have a good site, they tell u about the axle combo u will need for the tranny u will be using, if u have a s1 tranny then u can use 90-93 teg axles....As for the whole swap it is pretty easy i think one of the esasiest swaps to be done to a honda besides a b18a....I am guessing u have a 88-91 civic or crx, if u do than it is simple, if u have multi point already and dont have a hf....If u have 88-91 civic si then basic swap get mounts, engine, tranny, half shaft, the pr3 ecu or pw0, and then run 4 new wires to the ecu, knock sensor, secondary o2 sensor, vtec selinoid, and oil pressure sender....then u will need custom shift linkage u can use yors and lengthin it, or hit up hasport.com or hcpengineering.com....If u dont have a 88-91 civic sorry for posting..thanx
-Braxton
-Braxton
if you have the money and ability i would grab the cv's, tranny, mounts, ecu, and wire harness...may be over kill but atleast you wont have to worry about anything not fitting or working
Bizzare Customs
Land O' Lakes, FL
Bizzare Customs
Land O' Lakes, FL
