Vehicle speed sensor
Old Jul 26, 2004 | 03:29 PM
terry.ho's Avatar
I love to choke people.
Default Vehicle speed sensor
Does anyone have a VSS for a B16 that I can use to test if that truely is the problem with my car. It keeps throwing code 17 and the CEL comes on during decelleration in a gear. Also VTEC is not activating and around 70 mph the car shuts down like it has hit it's speed limiter. But this is intermitten. Don't want to speed money if it is actually something else.
Originally Posted by fresh&clean
This is the worst place to get any advice at all.
http://www.myspace.com/terry_ho
Old Jul 26, 2004 | 06:38 PM
lsrex212's Avatar
is if a mechanical vss or electronic vss?
Old Jul 26, 2004 | 10:07 PM
terry.ho's Avatar
is there a difference. I have a 95 Sir2 motor.
Old Jul 26, 2004 | 10:13 PM
lsrex212's Avatar
there is a difference, the mechanical uses a speedo cable from trans to gauge and wire to ecu.....the elec. uses wires from trans to gauge to ecu...does your speedo work? have you made any modifications to your gauge cluster recently....and also what car is this motor in?
Old Jul 26, 2004 | 10:51 PM
rangcrx's Avatar
engine building &best
92+ id Ess 91- is Css i wouls check to see if its covered in oil or if you hit a bump and it broke Its easy to see if you have a b16swap its right behind the starter check it 10mm bolt a super long extesion will make it easy to take out
i love AUTOZONE
Old Jul 27, 2004 | 06:26 AM
terry.ho's Avatar
It is an electrical VSS. I have pulled it out to look at it and put it back in. Everything on it looks good. The speedometer is working fine. I have a JDM B16 in the car. It only throws the code when I'm decelerating in gear to a low RPM. And every now and then when I'm just crusing. Around 70 mph the car will shut down for a second while the speed drops and then kicks back on. But if I hard accelerate past 70 mph this doesn't happen.
Old Jul 27, 2004 | 08:02 AM
RidingNiceRice's Avatar
BIG HONKIN POS !
I know what it is!!!!!!!! and it is none of the above I had the same problem. Your going to kick yourself in the ass when I tell you!!!!!!!!!! wanna know
Old Jul 27, 2004 | 10:33 AM
accord95's Avatar
USMC
do you think it could be your ecu? i heard yours got covered in water.
TR happily married crew-member #2
___________________
Originally Posted by Troux
This is the internet. You're just supposed to talk up whatever you do know as if you're a salesman for it. i.e. I drive a Supra and a Corolla therefore 2JZ is the greatest and so is the 4A and I don't care about anything else because it's all crap since I don't have it. I also have a stack of $20 bills in front of me, therefore 20>50 and 20>100 and 20>1000. $20 bill FTW.
Old Jul 27, 2004 | 02:11 PM
terry.ho's Avatar
So what is it?
Old Jul 27, 2004 | 02:14 PM
terry.ho's Avatar
It is a possibility but very little water got in the ecu. It mainly puddled up in the plug. I would also think if it was the ecu it would be more than an intermitten problem. The car runs great and idles perfect.
