Anyone have a factory service manual?
Old Jul 26, 2004 | 08:20 AM
Josh's Avatar
Dr. Doom
Default Anyone have a factory service manual?
Anyone have a service manual from Honda for a 99 integra GS? I'm trying to see what tools are needed and what all is involved to do a valve adjustment so i can do this myself. any help is appreciated, thanks!
Old Jul 26, 2004 | 08:50 AM
99B16Si's Avatar
rachet
10mm socket
12mm socket
19mm socket
an extension
flathead screwdriver
feeler gauges (.004 intake, .007exhaust)
and about 30 minutes and your done
Old Jul 26, 2004 | 08:53 AM
Josh's Avatar
Dr. Doom
damn, that's it? thanks mang. where could i get feeler gauges at?
Old Jul 26, 2004 | 09:00 AM
Josh's Avatar
Dr. Doom
and how exactly do you measure the clearance, like the process in detail? thanks.
Old Jul 26, 2004 | 09:17 AM
24-7's Avatar
Civic Racing eXperiment
Any automotive tool retailer.
Old Jul 26, 2004 | 12:34 PM
Josh's Avatar
Dr. Doom
k, i got the feeler gauges, now what about the process?
Old Jul 26, 2004 | 12:40 PM
99B16Si's Avatar
make sure u get the angled feeler gauges or else youll have a serious problem.
process in a nutshell is:
start with the motor at TDC then do cylinder 1, rotate the crank counterclockwise 90degrees then do cylinder 3, rotate another 90 then do cylnder 4 then another 90 and do cylinder 2.
theres obviously a little more too it but youre measuring the clearance between the cam and the rocker
Old Jul 26, 2004 | 12:42 PM
Josh's Avatar
Dr. Doom
i did get the angled gauges!!!! go me!
sounds simple enough, and if it needs adjusting?
Old Jul 26, 2004 | 01:04 PM
99B16Si's Avatar
loosing the locking nut, turn the adjustment screw with a flathead, then tighten it down. make sure the screw doesnt turn more when u go to tighten the nut tho
Old Jul 26, 2004 | 01:29 PM
Josh's Avatar
Dr. Doom
gotcha, sounds like a project. i'll post up pics and the results. thanks again dave!!!
