Rod's need help with this
Ok got a 91 ls in a 88 crx. I spun a rod bearing. Now I know that I need a new crank (got that already), But can I use the same rod that had the spun bearing on it?
I got some stock rods and piston from some one on here and the numbers on the pistons and rods are different then the ones on my piston and rods. Can i still use the piston and rod i got? If so then how can i clean them. They are oil soaked. And the piston got a lot of carbon on them?
Thanks for any help i can get.
Aim: Hondacrxls
Aim: Hondacrxls
its not a new rod and piston its just some stock one out of a ls
and the piston reads pr4 .08
the rods reads pr4 65-
and the bearing part on the rod reads 35-pr4
Aim: Hondacrxls
Aim: Hondacrxls
engine building &best
on
yes you can use them if thay are from a ls but are you sure what do the other rods numbers say?
i love AUTOZONE
i love AUTOZONE
