ls tb.
Old Jul 24, 2004 | 12:54 PM
TSX24L's Avatar
Default ls tb.
Can i bore a ls throttlebody? And use it on a na lsvtec?
Old Jul 24, 2004 | 01:38 PM
Josh's Avatar
Dr. Doom
only a couple of millimeters
Old Jul 25, 2004 | 06:57 PM
silver ac's Avatar
high on revs
i have an h22 throttle body that might be what you need (or want0 that is if it works
Man, I miss this car!!!
Old Jul 25, 2004 | 06:59 PM
NChatch's Avatar
i stepped on my weiner!
H22 will work fine i had one on my B16.......go to www.maxbore.com
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Jul 26, 2004 | 08:18 AM
TSX24L's Avatar
I will most likely go to obd1. I have a b16a1 tb laying in my garage. I also have a 94 ls tb. obd1 What do i do and what would be best?
NChatch thanks alot for that site. I will sending my tb to him Wednesday. as soon as i get a answer
Old Jul 26, 2004 | 08:19 AM
Josh's Avatar
Dr. Doom
the b16 tb is a couple of mm bigger already.
Old Jul 26, 2004 | 08:23 AM
TSX24L's Avatar
what about the obd0-1 will it matter what tb i use?
Old Jul 26, 2004 | 08:25 AM
Josh's Avatar
Dr. Doom
you may run into a problem with your TPS sensor, but should bolt right up.
Old Jul 26, 2004 | 02:19 PM
NChatch's Avatar
its not the TPS issue its the map, obd1's are on top, obd0's and on the firewall seperate from the TB
owner/operator
