once LS/vtec'd can a head be used on a vtec motor?
Old Jul 24, 2004 | 07:10 AM
NChatch's Avatar
i stepped on my weiner!
Default once LS/vtec'd can a head be used on a vtec motor?
once done for ls/vtec can you put the head back on a vtec motor??
would you just run the oil line like you did for the ls/vtec?
and then supposing you didnt use aftermarket dowels, would you have to have the vtec block drilled for the different pins??
Old Jul 24, 2004 | 07:28 AM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
yes it is possible. but i would just remove the line and plug the hole up
tamparacing.com
Old Jul 24, 2004 | 08:26 AM
FlatFour's Avatar
Cock Model
damn mike, cmon man.....all u do is remove the 1/8npt plug from the bottom of the head, put the other larger plug back in the backside of the heaqd near the distributor and put the dowels back to the factory location....boom done
99b16si
02 WRX
K&N, ic hoses, up-pipe & turboback
Old Jul 24, 2004 | 10:05 AM
NChatch's Avatar
yeah but im saying, i used some JB weld in the oiling hole in the bottom of the head, i just dont forsee it coming back out now.....i guess i could drill it,
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Jul 24, 2004 | 10:21 AM
rangcrx's Avatar
engine building &best
i would cause if you dont and use the Ss you will have to block the block hole
i love AUTOZONE
Old Jul 25, 2004 | 08:18 AM
99B16Si's Avatar
well u didnt mention that the first time did u?
if worst comes to worst and it wont back out take it to a machine shop...theyll get anything out
Old Jul 25, 2004 | 10:54 AM
NChatch's Avatar
yeah thats what im thinking too
owner/operator
