crank pulley nut
crank pulley nut
i am trying to get the crank pulley nut off and having a hard time doing it. i tried the breaker bar and impact wrench approach and it did not budge. anybody have a new idea? also is the nut counter threaded, in other words not lefty loose righty tighty. thanks for any help. if somebody would like to help with a waterpump removal let me know.
I really dont know what engine your trying to do this to.My old zc motor was loosen to the right,tighten to the left.Which way does the engine rotate?
Oscar
90 Tsi=FOR SALE $1500 O.BO
93 Eg Hb=b20vtec wit nawz
Rotary Farm Vato Locos crew member #0 biatch
Oscar
Unless you have a decent size/hp compressor and a nice impact gun you'll need a breaker bar and a friend. Have your friend hold on the brakes and just take your breaker bar and knock the nut loose (counter clockwise). She'll come off..
-Mike
-Mike
http://www.myspace.com/jdmmike02
2000 Ford Expedition Eddie Bauer
2004 Kawasaki ZX6R - SOLD
The correct tool is a moroso or honda crank pulley tool.
It is a 52mm tool which holds the crank pulley in place.
You use it along with a breaker bar.
well we finally got the crank pulley nut. after taking off the timing belt we were going to change the cam pulley for a adjustable one and thats when the worst could happen. the bolt that holds the camshaft pulley in broke in half. will a machine shop beable to get the rest of the bolt out or am i sol. thanks for any help.
get a reverse thread drill bit and drill a deep hole in the bolt than use a easy out and a drill in reverse to dack the remains of the bolt out, works everytime and quick and easy
