big ls/vtec problem
LS/VTEC, thats whats wrong with it. lol! firing order sounds like one problem or maybe cause you are using a SOHC VTEC dizzy. I didnt think SOHC and DOHC parts were interchangable. I have no idea about the oil leaking out the head gasket. could the gasket go on upside down with the dowel pins in??
did you seal vtec oil feed hole in the head. Even if you did have a plug threaded in it needs to be sealed really well. I use JB weld on the threads, Honda bond and locktite has also worked for me in the past.
Gracie Barra Clearwater
thanks for the help,i figured out the oil problem just need to find out about the spark problem,any other info would be great, and the firing order is right and plugs are in right.
what was the oil problem?
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
yeah what was the oiling problem???
i would swap in a different dizzy to see if that helps,
what year and chassis is it in, i mean dx,cx,vx,hf and year??
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
the oil problem whas that the pins that hold the 3 layers of head gasket were still on the head gasket which caused it not to seal properly,so i just went out and bought another gasket and took the pins out so the head seats better,and the chassis that the motor is in is a 91 dx but is converted into a si,i had a stock LS motor in it before and it ran perfect,but then i just decided to go ls vtec and now its giving me this shit spark problem.the thing is i tried my stock LS dizzy and that also didnt work and then we pulled a dizzy of my friend civic with a b16 in it(he's runnin a SOHC dizzy and it runs like a champ,i mean no problem at all), i know for a fact that there is no wiring problem, its gotta be the distributer or some other shit, i'm gonna keep working on this till i figure this out and i will post the result,thanks for all the help.
