No clutch after swap?
Old Jul 21, 2004 | 10:36 AM
CXHatchback's Avatar
Currently Ballin'
Default No clutch after swap?
I just put a new engine/tranny into my 94 civic. Straight d15b7 to d15b7. The motor's in and runs great but I can't get any pressure to build in the clutch. We tried bleeding it but it won't really build any pressure. We swapped slave cylinders from the trannies but to no avail. Any ideas besides the clutch MC?
Old Jul 21, 2004 | 02:12 PM
KJ's Avatar
KJ
bored at work
did you put the throwout bearing back in. Friend of mine did that once.
Old Jul 21, 2004 | 02:57 PM
Josh's Avatar
Dr. Doom
Originally posted by `92CXhatch
i would say MC...
-Keith
+1
and any fluid leaks?
Old Jul 21, 2004 | 03:17 PM
NChatch's Avatar
i stepped on my weiner!
check under the dash to see if the piston inside the master cylinder is leaking, then also you may need to bleed that slave cylinder for a while, i bled mine for like over 30 minutes and it didnt do shit, then we bled it for like another 15 and bam it all of a sudden worked
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Jul 21, 2004 | 06:31 PM
Currently Ballin'
WTF is that? lol, don't know too much about the clutch components.
How do I bleed the slave cylinder? We were just bleeding it like brakes, lossening the bleed screw and pumping the pedal.
Another thing I think might have happened is dirt got in the lines and is clogging something, because the fluid is filthy and there's no filter in the reservoir.
Old Jul 21, 2004 | 06:47 PM
B16aTeggy's Avatar
My Balls Hurt
ya my accord is doing teh same thing.. id tryed everything.. no leaks.. we got lil pressure once but we tryed to bleeded it again but it went away.. now i can get anything!!!..
help! lol i need to get this done so i can go to the track!!!
bikes
-73 kawasaki z1 900/ 05 cbr600rr motor
-06 675 117whp 52fttq
AIM- B16aTeggy
Old Jul 21, 2004 | 07:06 PM
MadisFastDSM's Avatar
tractionless
clean the lines.......... check rubber gaskets around mc and then rebleed lines
collision and refinising technician need bodywork/ paint call 727 776 7830
Old Jul 21, 2004 | 08:43 PM
Currently Ballin'
Do you think getting a vacuum pump would help? I think I'm gonna rent one tomorrow to clear out the lines and start over fresh.
