93 prelude
Old Jul 15, 2004 | 02:44 PM
93redlude's Avatar
realfucnfast
Question 93 prelude
Ok you all helped with the last problem. So here we go again, I think the water pump is bad on my car. I have a steady stream of water pouring out of the weep hole. The car will not hold any water what so ever. Could this be the problem or is it something else?...........Dave
Old Jul 15, 2004 | 03:59 PM
blurboEK's Avatar
proud father ;D
weep hole? do you have a picture of what your talking about?
-Mike
http://www.myspace.com/jdmmike02
2000 Ford Expedition Eddie Bauer
2004 Kawasaki ZX6R - SOLD
Old Jul 16, 2004 | 07:05 AM
93redlude's Avatar
realfucnfast
Default pic
This is the page from my manual
93redlude's Avatar
realfucnfast
Default pic
93redlude's Avatar
realfucnfast
Default pic
Old Jul 16, 2004 | 08:17 AM
RidingNiceRice's Avatar
BIG HONKIN POS !
holy triple posts batman!!!!!!
Old Jul 16, 2004 | 08:52 AM
blurboEK's Avatar
proud father ;D
any waster is steadly comming out? how many miles are on this water pump? I'd say just replace it. don't forget to pick up a new gasket and hondabond. Check your timing and balancer belts while your at it.
-Mike
Old Jul 16, 2004 | 09:12 AM
93redlude's Avatar
realfucnfast
Yea that is what I thoght but it is going to be one hell of a job, i am going to have the pull the whole motor. the WP has about 90k on it. I just really did not want to get in it so far........Dave
Old Jul 16, 2004 | 01:33 PM
blurboEK's Avatar
proud father ;D
You can install it with the motor in the car, you'll need to use an engine hoist so you can remove the drivers side motor mount. You can check with the local shops.. but I'm sure it'll cost an arm and a leg...
-Mike
Old Jul 17, 2004 | 10:57 AM
dropcivic's Avatar
Redneck Proud
Going through honda, your looking at about 600 to do the t-belt, cam seals, crank seal, blancer shaft seal, water pump, balancer belt, and all the accesory drive belts. We do it as a package, and no, you don't have to pull the motor
Honda certified Tech
Southern Pride not racism
