vtec vs. non vtec dizzy
Old Jul 11, 2004 | 01:18 PM
kender's Avatar
gadget man
Default vtec vs. non vtec dizzy
ok I know all bseries dizzy's can be bolted to all b series heads but do you have to make sure that the dizzy is vtec for it to work on a vtec head. I have a vtec b16 and am getting a dizzy from a b18 but don't know if its vtec or not. thanks
U.S.S.A Crew Member #001
Old Jul 12, 2004 | 08:38 AM
juiced2ndgenteg's Avatar
it wont fit in its stock form. if you use a non vtec dizzy on a vtec head you would need to grind one "leg" off. without grinding it the "leg" would hit the vtec solenoid. you also have to make the slot for the top bolt longer, alot longer. its not that hard....
Old Jul 12, 2004 | 04:13 PM
kender's Avatar
gadget man
the dizzy I'm looking at is from an ls, I'm not too familiar with the ls, so is the oem ls b18 always a vtec engine
Old Jul 13, 2004 | 07:33 AM
hybrid ek's Avatar
Has a little 1 on the way
ls is non vtec
Originally Posted by MajinVegeta
body kit-$400 dollars.
'custom' interior with walmart floor mats- $200
turbo gauges without boost- $200
realizing all that money wasted on rice- priceless.
Old Jul 13, 2004 | 08:31 AM
rangcrx's Avatar
engine building &best
is it going into youe crx?if it is use a crx si distributor it works so much better and you can buy them brand new for 170bucks and you dont have to make the holes bigger or anything : o) auto zone has them in stock
i love AUTOZONE
Old Jul 13, 2004 | 09:48 AM
kender's Avatar
gadget man
yeah its goin in the crx, but I'm upgrading to obd1 and its a b16 vtec engine, the si oem motor is d series and non vtec.
Old Jul 13, 2004 | 09:57 AM
kender's Avatar
gadget man
oh heres another ? why couldn't I take the bottom plate ( the one that needs the leg cut off and the hole lengthened ) and swap it with the obdo vtec bottom plate? is the plate permenantly attached to something obd1 specific, or are the holes for the rotor different? just a thought. has anyone tried this?
Old Jul 13, 2004 | 05:13 PM
rangcrx's Avatar
im just saying you can buy a brand new crx si distibutor and cut of one post from it and the other 2 will bolt up and use it but if your going obd1 then the ecu is different..not to sure what you mean about what you said up top your distibutor is a solid case just buy a 92-95 integra Gsr distributor
i love AUTOZONE
Old Jul 13, 2004 | 05:34 PM
kender's Avatar
gadget man
I'm trin to get ahold of a vtec b series obd1 dizzy but it's hard to to find one used for a good price. budgets suck I need to win the lotto.
