Shifter
WTF would allow a shifter to move all the way from left to right even when it's in gear. This tool says that it's a Si shifter mated to a 5 speed mystery tranny, don't really know what it came out of. Is it that the shifter is busted or not installed right?
I love completing other people's abandoned projects?
"There's more flawless engineering in a Camry than all the berlinettas Enzo ever conjured while lying next to mistresses." - John Phillips/Car and Driver
The swapped hatch hotness
Slow Five-Oh Rustang
Originally posted by FifteenEighty
explain more what u mean move all the way from the left to the right?
There is nothing causing the shifter to return to the space in between the 3 & 4 gear, when in neutral.
A friend of mine purchased an ef w/ a b16 swap that was doing this. End result was that the bolt/nut that the kid was using as a shift linkage pin was allowing play in the shift linkage...
Make sure you have a properly installed OEM shift linkage pin.
THANX!!!
