CEL for misfire
Check compression first
check cam timing
check ignition timing
tune-up ignition stuff
Honda's use signals from the CKF sensor on the crank and the distributor. When they are not matching a set requirement it activates the CEL. There could also be intermittnet problems with those sensors.
check cam timing
TR Balla Donor Supreme
on
Thank you ill try this stuff tomorrow, keep the suggestions comming
1998 crv daily beater
on
i took off the msd wires and put on stock wires, i havent had a cel since, so im not sure
