flywheel or not?
on my new d15b vtec. there is a piece connectected to the block tranny side with the same bolts as the flywheel but it has no teeth its bronze with some holes in it. stock holes not corrosion.the bolts say AT on them.. anyone know what it is.thanks
Chris
Chris
USAF
USAF
A T means automaticTransmsission it looks like a big bowl you have to take that off if your converting to 5speed BUT YOU CAN NOT USE THOSE flywheel bolt to bolt up a manuel flywheel
i love AUTOZONE
i love AUTOZONE
i pmed youback about it its not a flywheel it is a torque converters made for autos the reason you 8 bolts say at is for AutomaticTransmission,you have to take off all the 17mm 12 point bolts and get manuel bolts and a manuel flywheel and it will bolt right up to those holes MAN SURE YOUr new flywheel has a polit bearing b4 you bolt it up its a round bearing that is softly pressed into the hole in the flywheel
i love AUTOZONE
i love AUTOZONE
it actually IS a flywheel of sorts.... He is not talking about the torque converter, he is talking about the thin flywheel that the torque convertor sits on... and the reason there are no teeth on that flywheel, is because they are on the torque convertor.... just remove that, attach the 5 spd flywheel with 5 spd bolts, and you'll be good to go.....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Guest
Posts: n/a
